Author Topic: Temp sender...  (Read 996 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Temp sender...
« on: 27 February 2008, 16:09 »
Hi, i have a set of 3 TIM guages and one is a water temp sender... it comes with a small brass sender unit and a few adapters but the golf engine has a plastic sender that plugs in (and a spare plug next to it)
I cant connect the TIM guage to the stock sender as it said it will almost certainly be diffrent and give the wrong reading... How do i go about fitting this after market sender?  Its brass and needs to be threaded into metal for the earth.
Cheers.  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
