Author Topic: Lowering my ride ...  (Read 3035 times)
Offline LazyLunatic
  • MK3 20VT Project
« on: 26 February 2008, 22:04 »
Hi all,
I'm in deep water here, not sure what to do. I want to lower my car 40/40 but not sure if it is possible to do myself?!?!
Can I just buy a hottuning lowering kit and fit it myself or is it harder?
LL ;)
Offline Mikester
  • Civic Type R
Re: Lowering my ride ...
« Reply #1 on: 26 February 2008, 22:04 »
Hi all,
LL ;)
might need an extra pair of hands, to compress the springs to get the old off?
Offline saul79
« Reply #2 on: 26 February 2008, 22:09 »
spring clamps and tools and you could do it ur self
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3 on: 26 February 2008, 22:12 »
So can I simply just take off the old ones and put the new hottuning ones in. My m8 will give me a hand, I'm not strong enough! haha!
Is there anything that I should replace while I'm at it, that may improve handling or would be just good to replace?
Cheers for the reply m8
LL ;)
Offline LazyLunatic
  • MK3 20VT Project
« Reply #4 on: 26 February 2008, 22:13 »
I'll check my funds and order them soon!
Offline saul79
« Reply #5 on: 26 February 2008, 22:14 »
top mounts front and rears
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 26 February 2008, 22:15 »
its also wise to replace the top mounts while your fitting them oh and you'll need a tracking check/adjust at least.. add another £60 to the total
Offline LazyLunatic
  • MK3 20VT Project
« Reply #7 on: 26 February 2008, 22:25 »
cheers for the help guys!
LL ;)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #8 on: 27 February 2008, 12:50 »
Tracking should be done but more importantly your camber will be out!   I had realy problems undoing the top mount nuts, I needed to use a powerfull air gun because the shock just span!   Drop into your local garage and ask them nicely to bang them off and on a few times so its loose ready for you to do the job.  every thing else will be a doddle  :wink:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
