Author Topic: think its fooked!!  (Read 1467 times)
Offline bundy
think its fooked!!
« on: 26 February 2008, 18:55 »
ive just been given a mk2 gti 8v theres no smoke from it or anything but its only running on 2 or 3 cylinders. ive cleaned all the plugs and ive got a spark going through each lead, havn't tested the compression in each cylinder yet. if anyones got any idea of what it could be please let me know.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: think its fooked!!
« Reply #1 on: 26 February 2008, 19:45 »
Make sure the plugs are connected the right way,  (in the correct firing order)  If you muddle them up somtimes it will run but only on 2/3 cylinders!!  Pops and backfired are a common give away.
Check that first because i have done it many times!
It will be somthing like 1-3-4-2  So find out where number 1 is on the dizzy cap and ensure the ones that follow it connect as shown.
On the distributor            Spark plugs
Plug1        --->                Cylinder 1
Plug2        --->                Cylinder 3
Plug3        --->                Cylinder 4
Plug4        --->                Cylinder 2
Sorry if you already knew that, best to make it clear the first tiem just incase you dont know about the firing order  :wink:
By the way,  if you look down on the top of your distributor,  number 1, is TOP RIGHT
           2   1
             O
           4   3
Like that ^^^
And if that doesnt work,  you need a compression test  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline bundy
« Reply #2 on: 26 February 2008, 23:15 »
nice one thank ya, i just took for granted the bloke that gave me the car had them in he right order i think that 1 and 4 are the wrong way round on it.
Offline Rmachines
« Reply #3 on: 27 February 2008, 11:26 »
Nice easy fix if it is!   :wink:
Offline bundy
« Reply #4 on: 27 February 2008, 23:28 »
well, i checked and checked again and they wer ein the right order, took the plugs out of the barrels that werent running and put a bit of oil down to see if that helped and after a very loud bang!!it was still the same so its compression testing time!if that fails new head!
