Author Topic: 2 quick q's!  (Read 821 times)
Offline paultownsend
2 quick q's!
« on: 26 February 2008, 13:02 »
1. to do handbrake cables do you have to undo the exhaust heatshield? take exhaust off?
2. im changing my clutch and cable. its a 90'spec with that silly auto adjust. want to change to manual adjust. is the cable you buy from gsf enough? or is there anything else you need?
Paul
Offline JamesS
Re: 2 quick q's!
« Reply #1 on: 26 February 2008, 13:08 »
1. When doing my hand brake cables I didn't need to remove any heat shielding or remove exhaust.
2. I don't know.
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline Goops
  • mk2 gti 16v
Re: 2 quick q's!
« Reply #2 on: 26 February 2008, 13:42 »
I dont think you need to remove the heat shielding as the cables run parralel, there are clips on the sides if i remeber correctly!
