The garage
gear change noise
Topic: gear change noise (Read 1242 times)
evilelvis
Just got here
gear change noise
25 February 2008, 21:38 »
Ive noticed a high pitched short whine noise when I change down gears.I have a mk2 1.3, when I brake put the clutch in change gear and release the clutch thats when it happens.My ideas are
The clutch is grinding
the brakes need changing
Im releasing the brakes too early and the engine is jolting because of the high revs in a lower gear.
any ideas?
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Re: gear change noise
26 February 2008, 00:37 »
Not to sure exactly when this happens but it sounds like the gearbox?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Agreeable Slick
Global Moderator
Serious forum addict
Unit
26 February 2008, 00:44 »
alternatively the output shaft on the gearbox is a bit worn, sounds cool though cos it sounds like a straight cut box.
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
evilelvis
Just got here
26 February 2008, 19:55 »
Spoke to a guy today, he reckoned it might be the thrust or the diaphram.Just general old car stuff.He said not to worry about stuff until it happens.Its still bugging me though, just have to take it easier when Im bombin round country roads.
Rmachines
27 February 2008, 14:36 »
my box makes a right racket! belive me its loud! but is holding up well! lol it does sound like a straight cut dog box, which is very cool!
The garage
gear change noise
