Author Topic: Mk3 Gti holding back when accelerating  (Read 3251 times)
Offline difficultrogue
« on: 25 February 2008, 21:05 »
Hi I have just bought a 95 gti 8 valve I picked it up and headed straight for the petrol garage to fill up for the long journey home - The problem is this when squeezing the throttle slightly at cruising speed the car seems to splutter and hold back - something is clearly not good - I have just checked the paper work and it had a service 3000 miles a go! Your help would be appreciated.
Offline Kenny_1.6
  • it will be a GTi... some day... lol
Re: Mk3 Gti holding back when accelerating
« Reply #1 on: 25 February 2008, 23:41 »
fuel filter? not something they always replace during a service. replaced mine because mine was doing the same thing and all sorted now  :smiley:
Men have two emotions: Hungry and Horny. If you see one without an erection, make him a sandwich. :D
« Reply #2 on: 25 February 2008, 23:46 »
Yep Shes booked in for the weekend - New fuel filter time!
Offline Agreeable Slick
  • Unit
« Reply #3 on: 26 February 2008, 00:44 »
Iceberg in the way?
Offline Len
« Reply #4 on: 26 February 2008, 11:22 »
Sounds like it could be the old Mk 3 standard problem - ECU Relay!
Worth changing it anyway, they all fail eventually!
www.sas.org.uk
www.the-ace.org.uk
Offline Kenny_1.6
« Reply #5 on: 28 February 2008, 01:28 »
is this true for all Mk3's or just the GTi's? best site to get them from?
Offline Neaty
« Reply #6 on: 28 February 2008, 04:16 »
I have this same problem with mine, let me know if you sort it out as I would like to know.
Is it intermittant?
Mine has apparantly been replaced but still does it. any suggestions len?
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
« Reply #7 on: 01 March 2008, 13:39 »
theres loads of possible solutions for this in the mk3 forum....
fuel pump and ecu relays
throttle body and isv clean
new vac hoses
clean out breather pipes
new coolant temp sensor
etc
check out asome of the similar ones
