Author Topic: Radio, not working.  (Read 1714 times)
Offline Jez86gti
Radio, not working.
« on: 25 February 2008, 18:47 »
hello, ive made a mistake, wired up my stro, and connected the parking brake wire from head unit to the black wire on speaker loom. cd player does not switch on,  took it to guy in shop, and he wired it with a allways live feed and it works,  said i had blown a fuse somewhere, for it now to work the correct way, checked the fuse board and every thing seems ok,
am i missing somthing else?
please help,
thanks
Offline saul79
Re: Radio, not working.
« Reply #1 on: 25 February 2008, 18:49 »
has it got the tele on it ?
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Jez86gti
« Reply #2 on: 25 February 2008, 18:51 »
yer, a jvc one, with dvd player built in
Offline saul79
« Reply #3 on: 25 February 2008, 18:53 »
thought so as ur wiring it in to the parking brake .
Offline saul79
« Reply #4 on: 25 February 2008, 18:54 »
speaker wires are not fused so how could you off blown a fuse?
Offline Jez86gti
« Reply #5 on: 25 February 2008, 18:56 »
it worked wen the guy hard wired it to a permant live,   then it worked ok.
if wired up off the harness all tht works is the cd eject.
Offline saul79
« Reply #6 on: 25 February 2008, 18:58 »
so its working now then yes .all the fuses are okay .leave it pal  :smiley:
Offline Jez86gti
« Reply #7 on: 25 February 2008, 19:04 »
no, the guy told me trace it back to a fuse, so i toook his advice, checked the fuse for audio on fuse box, thts ok,   got feed live on the wirring harness,   just checking the wires on the harness  if they need switching,
Offline saul79
« Reply #8 on: 25 February 2008, 19:09 »
you will need one constant feed -red wire
one switched live from ignition normally yellow and/or red/yellow
earth
Offline saul79
« Reply #9 on: 25 February 2008, 19:15 »
there is normally a yellow wire and a red wire with connectors(head unit wiring) swap them round red to yellow and vice versa.
