Author Topic: I NEED HELP WITH WIPERS!!!!!!!!!! VERY IMPORTANT!  (Read 832 times)
Offline Khare
  • The bear that khares
« on: 25 February 2008, 18:08 »
I was unblocking the jet washers and when i went to test them the whole thing just stopped working. the wipers are now stuck in the vertical position, and nothing from the right thing on the steering wheel (were u turn wipers on and off ect) is working. I think i might have dislocated the selector thing. what u think? what can i do to heal my MK2??
Offline Agreeable Slick
  • Unit
Re: I NEED HELP WITH WIPERS!!!!!!!!!! VERY IMPORTANT!
« Reply #1 on: 25 February 2008, 18:10 »
check the fuses.
Offline Khare
« Reply #2 on: 25 February 2008, 18:12 »
i have, it sounds as if the arm thing isnt connected to anything in the steering column, sounds like its just moving with out making contact.
Any other suggestion on what to do?? i need the car tomorrow and the weather is looking like its gna rain! :sad:
  • Unit
« Reply #3 on: 25 February 2008, 18:33 »
easy way, whip the steering wheel off (25mm socket iirc) undo all the gubbins around the column, then unscrew the plate thats at the top of the column, and it will reveal all of the stalks connectors etc. Have a play, see if they have come off ( i doubt it) but it's worth a try.
Other way, have a look see if you mistakenly pulled the connector off the wiper motor. (under the scuttle panel on the drivers side)
Offline Khare
« Reply #4 on: 25 February 2008, 18:39 »
hey thanks for the help. but ive just managed to find out it ws the fuse. just needs replacing:D:D it blew. i'l gt one tomorrow. thnks anyway. very helpful:D
Offline Conker
« Reply #5 on: 25 February 2008, 23:08 »
Jeez, and you made slick type out all those instructions after he hit the bullseye with his first post!    :laugh:
Offline Khare
« Reply #6 on: 25 February 2008, 23:11 »
 :cry: sorry :cry:
just proves he's a good helpful guy though  :grin:
