Author Topic: Ah... New clutch is slipping!  (Read 2061 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 25 February 2008, 17:05 »
Hey,  i took my gti out for a spin for the first time since the new clutch and Gbox,  My clutch is slipping, quite badly!  it pulls away ok but if i put my foot down it spins up a bit!  Also it crunches into gear a bit,  would this be adjustment rarther than the clutch?  I did clean the new clutch parts but mabey not good enough?
Any ideas?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline stuckinarut
Re: Ah... New clutch is slipping!
« Reply #1 on: 25 February 2008, 17:44 »
hows the clutch cable? maybe it can be adjusted... usually theres a braket on top of the gearbox where the cable passes thru and theres a nut and bolt arrangement for tightening / loosening the cable. it could be that if it was tightened up too much the clutch isnt making proper contact and it is slipping. if that was the case, loosen off the cable adjustment a bit and it should let the clutch bite better..
p.s. im not a mechanic so if im wrong, sorry  :smiley:
Offline Rmachines
« Reply #2 on: 25 February 2008, 18:40 »
Its an auto adjuster cable fitted on this model (Its a MK3 by the way)  Possible the adjuster has locked up but the peddle feels fine!
Offline stuckinarut
« Reply #3 on: 25 February 2008, 18:51 »
cool, im not up on golfs yet, i just got mine and its already broke.. :huh: im guessing you replaced the release bearing etc as a full kit and not just the clutch plate?
Offline Rmachines
« Reply #4 on: 25 February 2008, 19:33 »
I fitted a new friction disk,  plate and cleaned up the fly wheel,  I fitted a new centre plate and retaining clip with that.   the old clutch was ok but i did this while the box was out.
Its possble it still had a little bit od grease on it i guess,  seems odd though.
Offline stuckinarut
« Reply #5 on: 25 February 2008, 19:41 »
i cant see grease affecting anything though, brakes fair enough but the clutch should exert a lot of pressure on the friction plate and its not metal so i always thought it wouldnt slip?
Offline Rmachines
« Reply #6 on: 25 February 2008, 20:01 »
A contaminated clutch will slip depending on how contaminated ofcourse!  I cant see why it would be slipping!  i cleaned it all before hand and im sure its not the clutch cable  :sad:
Offline saul79
« Reply #7 on: 25 February 2008, 21:57 »
worth checking the cable isnt on its last adjustment ,you can tell if its all crunched up on the auto ones
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Rmachines
« Reply #8 on: 25 February 2008, 23:00 »
Nah its about half way, same as my other golf.   im going to look into the adjuster tomorrow though.
Offline Kenny_1.6
  • it will be a GTi... some day... lol
« Reply #9 on: 25 February 2008, 23:44 »
my first guess would be that the clutch cable needs adjusted because its not sitting tight enough on the flywheel? had the same problem when i changed the clutch on my last car
Men have two emotions: Hungry and Horny. If you see one without an erection, make him a sandwich. :D
