Author Topic: Im confused about how to adjust my gear linkage  (Read 1443 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 25 February 2008, 16:17 »
I got the special VW Locking tool,  So i can lock it in neutral, then what do i do???    Somthing about a pinch bolt??  well i dont see anything,  help please  :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline saul79
Re: Im confused about how to adjust my gear linkage
« Reply #1 on: 25 February 2008, 19:04 »
Servicing gear selector mechanism
Adjusting gear selector mechanism
Notes:
The following points are essential to ensure correct selector adjustment:
◆ Perfect operation of selector mechanism, operating and relay elements.
◆ Light selector mechanism operation.
Also gearbox, clutch and clutch operating mechanism must be in perfect condition.
● Gearbox in neutral position.
‒ → Loosen clamp (arrow). Selector rod/gate lever connection must move freely.
‒ Pull cover off frame.
‒ → Insert gear stick jig.
‒ Jig must not stick.
‒ Align selector rod/gate lever (gearbox in neutral) and tighten clamp
Note:
Do not stress components.
Tightening torque
Clamp for selector rod
 25 Nm
Functional check
● The gear stick lever must rest in the 3rd/4th gear plane with gearbox in neutral.
‒ Select all gears several times. Pay particular attention to the operation of the reverse gear catch.
Should a gear fail to engage smoothly after repeated selection, then continue as follows:
‒ Engage 1st gear.
‒ Remove play from selector mechanism by carefully pushing gear stick to the left.
● → Distance -a- must then be 0.5 mm to 1.5 mm.
‒ Should this not be the case, carry out fine adjustment with 1st gear selected =>Page 34-22.
Fine adjustment
● 1st gear selected.
‒ → Loosen clamp bolt -B-.
‒ Set to dimension -a- by turning the adjustment eccentric -A-.
‒ Tighten clamp bolt -B-.
‒ Clip gaiter into frame.
Tightening torque
Eccentric adjustment clamping bolt
 2 Nm
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline saul79
« Reply #2 on: 25 February 2008, 19:07 »
 bolt loose underneath car 13mm bolt rod coming from gearstick to gearbox
  a- gearstick adjustment
  b  is little allen key on white part off gearstick
hope this helps
