Author Topic: Radiator Fans Golf TDI 150 (03)  (Read 2466 times)
Offline gib6107
« on: 25 February 2008, 09:22 »
Hi - I think I've read about this before somewhere but need to be 100% sure what is causing this.
What it is is that the radiator fans come on for about 3 seconds every minute or so, even when the engine is cold. VW said that the entire fan unit needed replacing so I got a 2nd opinion with a local mechanic who replaced the engine temp sensor and told me the problem was sorted out. However the fans are still coming on as before. This only happens when the A/C is switched on.
Could someone let me know if I really do need to get the entire fan unit replaced as a 100% certainty, as I'm guessing the work wouldn't be cheap, even outside VW. Thanks in advance.
Offline Uruk Hai
Re: Radiator Fans Golf TDI 150 (03)
« Reply #1 on: 03 August 2008, 22:00 »
Found this thread and web page, might be of help as it seems that it effects a lot of VWAG cars
Original thread :-   http://uk-mkivs.net/forums/p/59897/449470.aspx#449470
How to guide :-    http://website.lineone.net/~alan.james.lorely/fan%20mod/Repair.html
