Author Topic: Golf Mk4 Suspension???  (Read 1912 times)
Offline 00lewis
« on: 24 February 2008, 20:35 »
Hi all,
I am a proud owner of a VW Mk4 1.9 tdi golf 1998 (s-reg)
i have had the car about a year or so now and want to put the suspension back to its original spec, the previous owner has lowered it to far and often grounds on hummps and bumps, Iva had to remove the underside casing.
All i wish to know is what type of suspension will fit, do all golf mk4 springs fit all models???
I have seen "MK4 GOLF 2002 GTI SUSPENSION - SHOCKS/SPRINGS/ROLL BAR" is this likely to fit my golf?
Kind regards to all that read this,
many thanks
Offline Mooby
Re: Golf Mk4 Suspension???
« Reply #1 on: 25 February 2008, 10:44 »
You could just fit some decent coilovers - will probably cost a bit less than OEM suspension, and you could then simply adjust the height to what you require. :smiley:
I've got FK highsports on my MkIII, but they're a bit on the harsh side...
Sold the VR6... Now officially An Old Man With A Passat Estate.  At least it's a 1.8T :grin:
