Author Topic: water check  (Read 3299 times)
Offline Pete Taylor
Re: water check
« Reply #10 on: 24 February 2008, 22:13 »
You can lose oil through wear and tear such as worn piston rings but certainly not lose water. The only way water can leave the system is from a leaking rad, leaking hose, knackered heater matrix or a dodgey header tank cap. If they're all fine then the only other way is for it to sneak past the head gasket
Offline saul79
Re: water check
« Reply #11 on: 24 February 2008, 23:22 »
true
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Mikester
  • Civic Type R
Re: water check
« Reply #12 on: 24 February 2008, 23:23 »
Have you checked where you park up for water on the drive, and where it comes out if there is any?
Offline nelds
  • Now Golfless but owning an Audi still counts
Re: water check
« Reply #13 on: 25 February 2008, 10:13 »
just got back from garage, he said to keep an eye on it over next few weeks. Had a small amount of steam coming from bottom of rad so could need replacing, also got a collapsed breather pipe. The one that's fecked isn't even the correct type, someones previous bodge job....anybody know the part number..???
anyone got any comments on this
http://cgi.ebay.co.uk/Radiator-VW-Golf-mk3-2-0-GTI-16V-SDI-1-9-TDI-Vento-NEW_W0QQitemZ310025129968QQihZ021QQcategoryZ9889QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
Offline Pete Taylor
Re: water check
« Reply #14 on: 25 February 2008, 10:33 »
I bought that rad and it turned up last week, a week after buying it! Still not got round to fitting it to the car but it does look a decent rad from opening the box and taking a quick look
Offline nelds
Re: water check
« Reply #15 on: 25 February 2008, 10:36 »
easy job to fit..???.......does front end need to come off..??
Offline Pete Taylor
Re: water check
« Reply #16 on: 25 February 2008, 10:37 »
grill, headlights, bumper and bumper support bar. Still an easy job though
Offline nelds
Re: water check
« Reply #17 on: 25 February 2008, 10:42 »
good excuse to straighten my bumper and paint it then.......had a slight corner knock
Offline Mikester
  • Civic Type R
Re: water check
« Reply #18 on: 25 February 2008, 12:33 »
Im only interested with an intercooler!  :laugh:
Offline Pete Taylor
Re: water check
« Reply #19 on: 25 February 2008, 13:22 »
That's why i'm putting off putting my new rad on. Got a new intercooler and a Mocal 13 row oil cooler to go on at the same time ;)
