Author Topic: rear brakes?  (Read 1793 times)
Offline ian007miles
rear brakes?
« on: 24 February 2008, 19:27 »
hi every one, right a quick question ive just renewed the rear calipers and rubber hoses changed for braded on my mk1 golf(rear discs), the thing is the old copper lines snapped so i replaced them too and now were i took the 2 brake lines off of the brake pressure regulator i cant remember witch pipe goes in witch hole does it matter. i meen the 2 pipes coming from the front of the car r in the right place cos i didnt disconect them. so theres 2 more holes 1 for the drivers side and 1 for the passanger side pipe but witch is witch ? please help me
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Re: rear brakes?
« Reply #1 on: 25 March 2008, 16:54 »
follow the lines back to the master cylinder and just make sure that each rear caliper is on the same circuit as the front caliper on the oposite sides.  The master cylinder has 2 cylinders in the front & rear half, so set it up so the front 2 holes work diagonally oposite calipers, and the rear 2 work the other 2 calipers.
