Author Topic: lowered mk4 golfs  (Read 1754 times)
Offline gti_mk4_2l
lowered mk4 golfs
« on: 24 February 2008, 10:35 »
hi i have lowered my mk4 golf 2l 8v gti i would like to know how or if at all possible it is to camber the wheels so the top is pushed into the arch more. i have standard suspension with lowered springs but will soon be purchasing coilovers or a rayvern airbag set up. depending on cash allowances
Offline GTi-Matt
Re: lowered mk4 golfs
« Reply #1 on: 24 February 2008, 10:43 »
probs possible but not recommended, id wait and fit ur coilovers before u think about that.
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline l4v15
  • GTi T 20v
« Reply #2 on: 24 February 2008, 15:06 »
it will just make your tires wear extremely fast on the inside edge. your camber will have naturally gone like that very slightly now that you have lowered it anyway. think its called positive camber
L4V15
Offline gti_mk4_2l
« Reply #3 on: 24 February 2008, 22:17 »
yes but how is it done on the rear because my local tyre fitters (merit tyres) said it cant be done but i have seen it done
Offline gti_mk4_2l
« Reply #4 on: 26 February 2008, 17:32 »
surely someone must know
Offline 20v
« Reply #5 on: 27 February 2008, 21:19 »
I HAVENT CHECKED ON MY GOLF BUT ON OTHER CARS THE REAR ARMS WERE THEY MOUNT TO THE REAR AXLE THERE IS A BOLT EITHER SIDE AN YOU CRACK THAT OFF AN THEN DEPENDENT ON WOT WAY YOU TURN IT DEPENDS ON WETHER YOU GOT + OR - camber not sure if it can be done on the golfs tho
Offline gti_mk4_2l
« Reply #6 on: 29 February 2008, 01:28 »
sounds a bit iffy to me.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #7 on: 29 February 2008, 10:34 »
Don't know how local you are to them, but Awesome-gti offer a 'geometry set-up' service for lowered cars.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
