Author Topic: STEERING  (Read 1641 times)
Offline vrmk3
STEERING
« on: 23 February 2008, 21:55 »
Hi there ive got a mk3 golf vr6 recently noticed a funny noise so i jacked up my car a wobbled the front wheels to find that there was play on the drivers side i believe it could be the steering rack but im not sure if it could just be a tie rod arm? or will the whole rack need changing i checked the passenger side and that feels ok?
Thanks all
Offline filthy
Re: STEERING
« Reply #1 on: 23 February 2008, 22:28 »
Probably a track rod end, about a tenner from GSF  :smiley:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline saul79
Re: STEERING
« Reply #2 on: 23 February 2008, 22:45 »
one is adjustable the other isnt .
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline boneybradley
  • Back in a Mk3...
Re: STEERING
« Reply #3 on: 24 February 2008, 00:20 »
sual both my track rods are adjustable...its the vw no common parts thing again!!
Offline Pete Taylor
Re: STEERING
« Reply #4 on: 24 February 2008, 02:57 »
If the play was in all directions it's more likely to be wheel bearings
Offline vrmk3
Re: STEERING
« Reply #5 on: 24 February 2008, 10:03 »
Thanks all
cheers for the replys ive had a look again i think the wheel bearing is a little worn also i checked the track rod end and it seems ok the play looks like its coming from other end by the steering rack i assume theres a nuckle type joint is it possible to just change the arm? If so is it easy ? thanks again  :smiley:
Offline saul79
Re: STEERING
« Reply #6 on: 24 February 2008, 17:56 »
haha.isn't it
