Author Topic: could someone plz help me  (Read 1648 times)
Offline ro55
« on: 23 February 2008, 16:48 »
ive been havin some problems with my carb on my 1600 mk2 driver,its got a peirburg 2e2 on it,ive changed the carb with 4 different ones and the one thats on it now(the best out the 4)it ticks over at 2000rpm,when you pull of and put your foot down its flat like theres nothing there.ive replaced the plugs and leads,the timing is ok so what else could it be?could someone please help me as im not a very clued up about whats causing the problem?thanks
Offline herbster
Re: could someone plz help me
« Reply #1 on: 23 February 2008, 17:03 »
it should only be tickin over at about 1000rpm, no more unless the choke is on, sounds like the jets and adjusting screws are all out of sync, if carb is not set right all sorts of problems can come, hence why the industry went on to fuel injection, easier to determine where/which bit is set wrong. The throttle valve in the carb along with the jets is set to the engine, alot of people get off the peirberg onto a weber due to these problems, the main one was the auto choke, even played up after a manual conversion, like the carb was looking for the extra fuel etc...
Flat spots on a carb system can come from bad vaccum system ie leaking, miss configured or non functional, check the diaphram on the side of the disi, take the pipe off whilst running engine and put finger diaphram exit pipe and move the throttle you should feel a suck on your finger, check the pipe into the rear of the clocks too, i'm sure you'll get it sorted, its a dub!  :wink:
FAB is my life and the CABRIO's the wifes!!!!
Offline Agreeable Slick
  • Unit
« Reply #2 on: 23 February 2008, 17:11 »
Offline ro55
« Reply #3 on: 23 February 2008, 23:48 »
could you tell me how to adjust it plz herbtser?
  • Unit
kcolevol
« Reply #5 on: 24 February 2008, 08:55 »
There is a guy i used to use on my twin webber 40's and he is a god a carbs, not sure where you are but he is in Basildon Essex, check out  www.redlinetuning.co.uk if your close enough!!!!
Offline ro55
« Reply #6 on: 25 February 2008, 17:12 »
if i replaced my peirburg with the weber carb would i have to get a manual choke conversion for it?
