Author Topic: flat spot.  (Read 1552 times)
Offline beni-iow
flat spot.
« on: 21 February 2008, 21:45 »
ive only had my gti for a just over a week and now ive got my abs sorted i opened her up for the 1st time properly but noticed that when i change gear fast it does not pick up straight away just feels like a flat spot.it also feels like i mite have a engine mount going.could a engine mount cause this or could it need a new fuel filter/ignition leads or plugs?
Offline Mikester
  • Civic Type R
Re: flat spot.
« Reply #1 on: 21 February 2008, 23:07 »
I have the same, when u change gear it feels like the engine is guna come through the dash.....
And also it dont pick up when u change gear..... I thought my clutch was going, but its not. I dont think that it has short shift gears? Maybe this would help?
Offline Len
Re: flat spot.
« Reply #2 on: 22 February 2008, 13:18 »
Fuel filter maybe?
www.sas.org.uk
www.the-ace.org.uk
Offline Mikester
  • Civic Type R
Re: flat spot.
« Reply #3 on: 22 February 2008, 13:53 »
Fuel filter maybe?
Yeah, i was thinking of this, i have it sittin on my desk, fitting it on monday XD
I will post up in this thread if it makes a difference.
Offline Kenny_1.6
  • it will be a GTi... some day... lol
Re: flat spot.
« Reply #4 on: 22 February 2008, 18:51 »
i've noticed this with my 1.6 too. mine's due a service though.  :undecided:
clutch dumping seems to sort it, but obviously not a good idea considering how soft Mk3 clutches are  :sad:
Men have two emotions: Hungry and Horny. If you see one without an erection, make him a sandwich. :D
Offline beni-iow
Re: flat spot.
« Reply #5 on: 23 February 2008, 00:01 »
i belive mine is now a engine mount just gota find out witch one it is  :angry:
Offline saul79
Re: flat spot.
« Reply #6 on: 23 February 2008, 15:40 »
to check if its the front -put it in 1st -h/brake on and let the clutch up .get a 2nd person to see if the front off the engine moves a lot -if it does its the front one .the rear mounts do the same in reverse and do the same and check both sides for it lifting -its mostly the front one and on occasions i've changed the gearbox ones ,but not many
hope this helps
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Pete Taylor
Re: flat spot.
« Reply #7 on: 23 February 2008, 16:00 »
Most likely a front mount. They're notoriously soft and crap as standard anyway. Get a diesel mount put on
Offline saul79
Re: flat spot.
« Reply #8 on: 23 February 2008, 16:29 »
i got the same one thats on urs a 2.0 16v one seems okay.
