Author Topic: changing a 4speed gearbox to a 5 speed  (Read 995 times)
Offline andyd1990
« on: 21 February 2008, 18:22 »
hi, i have a 1400cc mk 3 golf 4 speed L reg, the gearbox has recently given up on me so i have bought a 5 speed gear box which fits, i was jus wondering if there is anything else i need to change with it? ive been told i need to renew the clutch and flywheel is this true? thanks alot.
Offline saul79
Re: changing a 4speed gearbox to a 5 speed
« Reply #1 on: 21 February 2008, 18:24 »
depends what the gearbox is off ?
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline andyd1990
« Reply #2 on: 23 February 2008, 23:51 »
the same car but 5 speed
Offline saul79
« Reply #3 on: 24 February 2008, 17:58 »
check ecp for the part numbers see if there the same -i cant see why the clutch should be bigger .engine size is the same so shouldn't make no difference
