Author Topic: Clutch pedal - BROKE!  (Read 2071 times)
Offline Gt-tdi
« on: 03 April 2004, 12:29 »
i went to park my car the other day, pressed the clutch and WHAM! my foot almost went into the engine bay!!! the pedal came loose and i have no clutch power at all. It happend infront of my friends house (am mechanic) and i am thankfull for that BUT is this a common prob? He says its got to do with the gearbox connection i.e. pricey stuff.
TDI = economy and FAST!!
Offline nrgizerbunny
Re:Clutch pedal - BROKE!
« Reply #1 on: 03 April 2004, 13:07 »
well the clutch on my vw and according to my haynes manual is hydraulic, so master and slave cylinders as opposed to a cable.
when you press your foot down and there is no resistance, there is either a leak in the system or there is a problem with the friction plates and return springs.
i don't really know what your friend was eluding too?
have a nice day
sanj
Offline Gt-tdi
« Reply #2 on: 03 April 2004, 14:44 »
cheers mate!
Offline antgti
  • 130PD Gti with Van aaken chip to 165 has now gone,
« Reply #3 on: 04 April 2004, 03:18 »
Is this common with the PD engines due to the torque levels??
Me old diesel was quick/........
16.004 sec Qtr mile @ 85mph 23/5/04 Santa Pod
Now running around in soon to be REVO'd Seat ibiza 1.8T 20v FR and missing the fuel economy..............
« Reply #4 on: 05 April 2004, 09:41 »
i suppose its possible, diesels have much lower gearing than petrols so the clutch will see more torque. Having said that I think the diesel clutch is slightly bigger than a petrol?
have a nice day
sanj
golfvr6
« Reply #5 on: 06 April 2004, 10:39 »
Probably nothing to do with the clutch mechanical setup, far more likely to be a problem with the hydraulic system.
Try bleeding the system, if no air comes out , then remove the slave cylinder and make sure the rod is under spring pressure.
Offline SL56
Re: Clutch pedal - BROKE!
« Reply #6 on: 06 May 2005, 17:46 »
This just happened on my mk3 16v (hydraulic clutch) - pedal dropped and wouldnt return.
Turns out theres a cap behind the clutch pedal thats spot welded on in 5 places. This had come off so am now gettin in welded back on and jobs a good un  :laugh:
