Author Topic: Ruddy FUEL PUMP.........AGAIN!!! Wil my troubles ever end?  (Read 1259 times)
Offline Mikester
  • Civic Type R
So a few months back i posted my fuel pump kicked in really loud, this was when i ran the tank dry then filled it up with petrol. I figured this was the rubbish gettin stuck in the pump and after a day or two, the pump stop whinning, no problems. today i ran the tank all the way down and filled up, now i have the problem again, the pump is screming loud!! I have a new fuel filter that i havnt fitted. Would that fix it?
Or if i put more fuel in iit maybe it will slosh around and stop the noise? like before? Or is there a way to clean out the tank??
TeddyKGB
Re: Ruddy FUEL PUMP.........AGAIN!!! Wil my troubles ever end?
« Reply #1 on: 21 February 2008, 00:11 »
i don't know for sure but you shouldn't really let it run so low :shocked:
Offline Mikester
  • Civic Type R
« Reply #2 on: 21 February 2008, 00:16 »
Last day before payday!
Offline nelds
  • Now Golfless but owning an Audi still counts
« Reply #3 on: 21 February 2008, 06:53 »
ran mine on fumes last night too  :grin:
Offline oggy
« Reply #4 on: 21 February 2008, 10:17 »
The reason a fuel pump sometimes runs better with a full tank is that the petrol provides a positive suction head for the pump ie it assists the suction of the pump. As that head drops below a certain level, the pump has to work harder to to overcome the friction losses in the fuel lines and the static head involved. Certainly cleaning out or replacing the filter would help the pump - by reducing the friction losses it needs to overcome - and if you can, clean out the fuel lines. if all else fails it is time for a new pump. They do fail - usually on bearings - but it is not a difficult job to do if you can obtain access.
Offline Mikester
  • Civic Type R
« Reply #5 on: 21 February 2008, 11:32 »
Cheers, well at the moment it is just makin a bit of a noise intermitently. But last time it done this when i ran it dry it stopped after 10/20 miles of driving. Guess i will have to wait till it stops working, but i feel its not performing as well? :/
Offline saul79
« Reply #6 on: 21 February 2008, 18:18 »
you can clean the teabag on the bottom off it ,but you will need to take it out and dismantle it
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
