Cosmetic and bodywork matters
mk2 brake upgrade product advice req
Topic: mk2 brake upgrade product advice req (Read 1842 times)
gnarlysurf
Just got here
20 February 2008, 16:35 »
Hi,
Any advice on what 239mm drilled & grooved brakes i should buy???
How much should i be looking to spend for all full set of FR & RR inc pads?
...joe
Forum Supporter
Forum addict
Re: mk2 brake upgrade product advice req
20 February 2008, 18:50 »
if you go to
www.gsfcarparts.com
you should find all you need. i don't think they list them (but they do stock them, you might have to call a branch) but zimmerman drilled discs are good and inexpensive. them and some pagid pads will be fine for the front, just standard discs and pads for the rear as they don't have to work half as much as the fronts.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
mk2mark
20 February 2008, 18:55 »
Wouldn't really called drilled brakes an upgrade!
...joe
Forum Supporter
Forum addict
20 February 2008, 21:51 »
well there's not much of any upgrade to 239's then other than fitting 256mm 16v ones? thats just a tried and tested combo so should be fine.
VeeDubGTI16v
Guest
21 February 2008, 06:53 »
Quote from: mk2mark on 20 February 2008, 18:55
wouldnt really call them cosmetic either
