Author Topic: POWER STEERING SCREECHING  (Read 1647 times)
Offline gnarlysurf
« on: 19 February 2008, 17:41 »
Hi,
I'm in the process of restoring my MK2 Golf GTI 8V (1991) and the power steering is making a loud screeching noise when I turn the steering wheel...
Any ideas whats causing the problem and which parts need fixing ??
Also is it an easy job that I can do myself I'm not a novice but not a qualified macanic either..
Appreaciate any help on this..
Thanks
GS
Offline Uruk Hai
Re: POWER STEERING SCREECHING
« Reply #1 on: 19 February 2008, 18:54 »
Sounds like the belts slipping, either because its loose, worn out or both.
Offline saul79
« Reply #2 on: 23 February 2008, 18:11 »
or the pump is fecked
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #3 on: 23 February 2008, 23:36 »
check fluid level
Offline dabill
« Reply #4 on: 25 February 2008, 15:11 »
if the belts slipping, would this cause dodgy steering? i.e. really vague steering and sloppy steering?
noble tuned - and still not fast enough!
VeeDubClub
« Reply #5 on: 27 February 2008, 11:01 »
Hi mate.. I've got mk3 golf and my squeels when close to and on full lock, have been told that its nothing to worry about and most probly the fluid if thats any help!.
