Author Topic: Heated Door Mirrors DONT work!  (Read 2937 times)
Offline phulla
« on: 19 February 2008, 06:09 »
I have had my Colour Concept since 1999 and i really noticed the heated door mirrors dont work yesterday with -3 degree temp and thick covering of frost!
Does anyone know if there is a seperate fuse for them or is this common on these cars? Do i need to change the mirrors?
Offline eightyeightmph
Re: Heated Door Mirrors DONT work!
« Reply #1 on: 19 February 2008, 08:14 »
Pretty common fault, I think the bit that fails is part of the mirror itself so if you replace the lenses you should be ok again.
I only know about this from talking to someone who had the same problem so worth checking before you go & fork out for new parts.
2016 GOLF GTD
Offline Guy
« Reply #2 on: 19 February 2008, 10:03 »
remove the mirror and check that the contacts are still connected first
Offline RiCHiE360
« Reply #3 on: 19 February 2008, 10:17 »
Yup as guy said, check connections if that doesnt work you'll need new glass for them!
Roofless VR6 FTW
Offline gtiscott
« Reply #4 on: 19 February 2008, 10:26 »
do all gti's have them? if they do mine don't work either... does the glass  just pop out?
« Reply #5 on: 19 February 2008, 10:58 »
It does but can break, I found if you adjust it as far in towards the car as you can, you can 'leaver' it just enough to get as screwdriver in to unclip the first tab then leaver a little more to the next until it pops off.
2016 GOLF GTD
Offline gtiscott
« Reply #6 on: 19 February 2008, 11:26 »
just checked mine, passenger one looks melted on the back but drivers one looks fine...is there a seperate fuse for these that may have blown
Offline Guy
« Reply #7 on: 19 February 2008, 11:41 »
i found the easiest way to do this was to direct the mirror to the floor then wrap a blunt cutlery knife or similar in a soft cloth and insert that at the top of the mirror - it then just pops out - don't forget to support the mirror as you're doing this...
i wrote a thread ages ago about mirror glass removal and cowling removal and refitting... hold on... here it is...
http://www.golfgtiforum.co.uk/index.php?topic=68400.0
kells
« Reply #8 on: 19 February 2008, 17:07 »
use a bit wood in a wedge shape and prise them out...piece of piss, mine both work great btw  :wink:
Offline phulla
« Reply #9 on: 19 February 2008, 18:16 »
yeah, they used to work great, couple of minutes with the rear window heater on and the door mirrors would be steaming!
i will check the contacts, maybe give them a clean with some WD40, get the rust off the contacts.
cheers guys!
