Author Topic: mk3 VR6 cam chains replacement - garage quotes??  (Read 3283 times)
Offline saul79
Re: mk3 VR6 cam chains replacement - garage quotes??
« Reply #10 on: 19 February 2008, 17:54 »
i've done 2 of em pretty straight forward ,the ones i did though the engines where already out .there normally dont need changing -but vr's are common for headgaskets around the 100k so changing the chains at this time saves a few bob .
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Mr Blue
« Reply #11 on: 19 February 2008, 18:59 »
Saul
Is it easy with the engine in place? any other tips?
Whats the tentioner and chain cost roughly?
chers people :smiley:
Offline saul79
« Reply #12 on: 19 February 2008, 19:31 »
just quicket to take it out really or you will be pissing about in the engine bay.trying to work at an angle ,i got the parts from ecp -but i also got bearings for crank and stuff came to about 230 for everything.you will be looking at roughly 160 quid for tensioners and quides and the 2 chains.
« Last Edit: 19 February 2008, 19:34 by saul79 »
Offline zorro
« Reply #13 on: 19 February 2008, 20:23 »
The whole kit from VW comes in just short of £200 and unless youre a pretty competant mechanic and have access to ramps etc then i'd pay for it to be done.
I like playing about with the basic mechanics but didnt fancy tackling mine - look to pay anywhere from £200-£500 labour depending on where you go. Also a good idea to check the clutch whilst the box is out...
Have a look over on vr6oc.com loads of info about the chains on there..
HTH
Chris
2014 GTI PP
Offline Mr Blue
« Reply #14 on: 20 February 2008, 16:43 »
wiked
so its a gearbox off job by what im reading. :rolleyes:
Just had the covers off and the guide/tentioner is worn soo bad and broken in 4 :shocked: suprised it ran
Offline Mr Blue
« Reply #15 on: 23 February 2008, 16:14 »
give up for today
gearbox is being a right pain to get off.
See how i feel tomorrow :grin:
Offline saul79
« Reply #16 on: 23 February 2008, 16:27 »
remove the driveshaft cups gives you little moor room to get it out .circlip or 6mm allen key
