Author Topic: Driver door not opening  (Read 1499 times)
Offline madmanmavis
« on: 18 February 2008, 20:46 »
Got in the car just now and the door wouldnt open, may have been cold but didnt think it was that cold today?
Is this a common problem? (mk 3 8v Gti)
Just wondering before i tear the door apart!
Offline golfmk31993
Re: Driver door not opening
« Reply #1 on: 18 February 2008, 20:55 »
i have had problems with my drivers door,
firstly the lock mechanism in the door is broken, the little latch keeps dropping so when i shut the door it just hits the catch,
also on cold morning i put my key in the lock and it just wont turn were it has frozen shut,
anyone know how to fit a new lock mechanism in the door???
Offline kitto
  • NZ VW
« Reply #2 on: 18 February 2008, 21:58 »
Yeah mate, when its cold my drivers door wont open. Have to get in the passenger door and when i get to work its fine. I use a car cover when its cold. seems to help.
Hope this helps
Cheers Kit
Offline saul79
« Reply #3 on: 18 February 2008, 22:49 »
lube it with wd40 or grease (squirty stuff)
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline eightyeightmph
« Reply #4 on: 18 February 2008, 23:22 »
Haha! Had the same problem over the weekend! Had washed the car & the drivers door wouldn't budge, central locking wouldn't pop until it had warmed up!!
Ok now though as it's finally dried out. :wink:
2016 GOLF GTD
Offline Guy
« Reply #5 on: 18 February 2008, 23:54 »
i swear that i have seen a particular product for this problem somewhere... sometimes happens to me after a heavy frost  :angry:
Offline Pete Taylor
« Reply #6 on: 19 February 2008, 11:34 »
Locks sticking is usually caused by broken door hinges on 3dr cars. Bet the striker is cream crackered too. WD40 is no good to lube it, it's good for freeing it up and cleaning it but you need some proper grease spray in there
