Author Topic: N75-J valve  (Read 1406 times)
Offline samy_1800_turbo
N75-J valve
« on: 18 February 2008, 20:35 »
i have seen some one list a N75-J valve as a mod in the list your mods section, just wonderd what it was. is it to do with letting the boost pressure the the waste gate actuator.
Offline bobbarley
  • I'm kind of a big deal...
Re: N75-J valve
« Reply #1 on: 18 February 2008, 20:39 »
Quote
The N75J is part of the system that determines how much boost is held by the diverter valve. Often when you add a chip to a 1.8t powered VW, the increased boost needs a little more control to be smooth. The N75J not only lets the boost peak a little higher, but it also helps get rid of surging.
http://www.peterbeers.net/vw_roadtrip/GTI/GTI_Mods/N75J/N75J.htm
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: N75-J valve
« Reply #2 on: 18 February 2008, 21:10 »
I researched these valves a while back & the conclusion was about 50/50 to whether there was a gian or loss.  There was also a lot of talk about which valve was best for which engine code (there's the N75H/G/F as well).  In the end I decided to leave it.......
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Re: N75-J valve
« Reply #3 on: 18 February 2008, 21:22 »
i read the link above still dont get what the point of it is, wots it surposed to do n improve
