Author Topic: 'IN 02' flashes on dash when ignition is turned on?  (Read 1477 times)
Offline gsinnit
« on: 18 February 2008, 18:15 »
 :undecided:
Please Help:
When I switch the ignition on, where the milage is - flashes 'in 02' a couple of times then the milage shows again. Also the other digital display for the clock and mpg ect shows what looks like L's and dashes and is not displaying the correct readings. I have tried checking the fuse which i'v replaced anyway.
Can anyone shed some light on this problem.
Offline adyh
Re: 'IN 02' flashes on dash when ignition is turned on?
« Reply #1 on: 18 February 2008, 18:19 »
02 means you need a major service. [its done on a timer]
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 18 February 2008, 19:13 »
check this and it tells you how to reset.. http://www.golfgtiforum.co.uk/index.php?topic=8052.0 its for a mk3 but they are all similar
