Author Topic: correct oil temp?  (Read 3583 times)
Offline mk1
Re:correct oil temp?
« Reply #10 on: 02 April 2004, 20:15 »
Have seen mine at 110 lots of time, iirc 16v engines have oil jets that spray oil on the under side of the pistons to keep the crowns cooler.
Steve.
Offline jk8v
« Reply #11 on: 03 April 2004, 22:11 »
Mine does the same!! usually about 94-110c. But isnt that over boiing point, surely that cant be good?!  :-\
Offline gibby
« Reply #12 on: 04 April 2004, 01:06 »
You would think so jk8v and I thought the temp was in fahrenheit at first due to the temps involved, but 94c -110c is well within normal range.
......now officially dubless.
Offline mk1
« Reply #13 on: 04 April 2004, 09:40 »
Posted by: jk8v  Posted on: April 03, 2004, 22:11
Not over the boiling point of the oil and the cooling system is under pressure so even the coolant can be over 100 deg c and not boil. (thats why you should not take the cap off the cooling system when the engine is hot).
Steve.
Offline ooh_ooh_gti_crew
« Reply #14 on: 04 April 2004, 10:12 »
Mine shows nothing but a couple of dashes, any ideas on what mi8ght be the problem there?
Veedubgt18v
« Reply #15 on: 04 April 2004, 12:43 »
yeah your sensor isnt working/your mfa is shot/ your wire has come loose at sensor or mfa end
http://www.golfgtiforum.co.uk/gallery/displayimage.php?album=lastup&cat=17832&pos=1
yours wont have the 't' piece arrangement, but it will have the one at (the bolt thing) the back, check it is connected, or buy a new one from vag (?10)
« Reply #16 on: 04 April 2004, 18:20 »
I shall have a look at that then,
cheers.
Offline Pike
« Reply #17 on: 08 April 2004, 10:25 »
Another factor with tempreature is the grade/make of oil you are running. Quantum Silver is very stable at higher tempreatures, than comparative oils.
Golf GTI Championship #4
2008 VW1 3rd
2009 VW1 3rd
