Author Topic: correct oil temp?  (Read 3582 times)
Offline GavG60
  • keep my credit cards away from me please :-(
correct oil temp?
« on: 02 April 2004, 10:39 »
when warm, my 16v goes between 92 and 104 depending on how hard I'm beating her... ;)
is this normal? is 104 too high? if so is there anything you can do to flush / clean the system and oil cooler? is the oil cooler easy to take off and replace?
Offline gibby
Re:correct oil temp?
« Reply #1 on: 02 April 2004, 11:06 »
I've got a Rivage cab on a J plate so it is mk1 shape but it is the same era as the mk2 and in the handbook it says that the MFA displays temps from 50c - 160c, it also says that if the temp is 145c then you should slow the engine speed down so I guess 104c is normal and well within its limit.
As an aside, don't be beating her until the engine temp is 50c, apologies if you already know this  :)
......now officially dubless.
Offline GavG60
« Reply #2 on: 02 April 2004, 11:26 »
cool, cheers gibby. I usually wait till I'm over 70c just to be safe ;)
Offline gibby
« Reply #3 on: 02 April 2004, 11:37 »
No worries, maybe I'm not waiting long enough before I start whipping mine, waiting 5 minutes for it to get to 50c is hard enough ! Vrrrrooommmm :D
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 02 April 2004, 12:00 »
when sat at 100+ on the motorway mine was reading 120 one day. I dropped to cruising at 80 until it dropped closer 100c
Offline benjam_in
« Reply #5 on: 02 April 2004, 12:06 »
I think normal operating temp. is 80 but thats with normal driving!
Golf Mk2 Gti 1988
Offline GavG60
« Reply #6 on: 02 April 2004, 12:13 »
80?????? mine's never under 92 when its warm, even if I'm driving my gran :D
Offline gibby
« Reply #7 on: 02 April 2004, 12:50 »
There's not an exact running temp, it's a range, so normal running temp in the handbook will say something like 80c - 120c as normal.
Offline Gambit
« Reply #8 on: 02 April 2004, 14:29 »
aye mine sits between anything 90-118 depending on driving styles :P
Offline benjam_in
« Reply #9 on: 02 April 2004, 16:08 »
I recon its you big bumpers stopping air getting to your engines!  ???
Golf Mk2 Gti 1988
