Hmm, what does happen if the battery dies then? I guess you are buggered?CS
Quote from: consumerway on 17 February 2008, 22:24Hmm, what does happen if the battery dies then? I guess you are buggered?CSNo you climb through the boot
Quote from: richw911 on 17 February 2008, 23:13Quote from: consumerway on 17 February 2008, 22:24Hmm, what does happen if the battery dies then? I guess you are buggered?CSNo you climb through the boot As long as there is a way in with the key then i don't see an issue if it can help towards security.CS
So i'm looking at getting a de-lock kit - where is the cheapest place?Also, can I just confirm there is still a way into the car if the battery dies.. eg via key through the boot? I don't want to re-wire a battery point.Thanks,CS
