Author Topic: MK3 golf GTI 2.0 8V with running trouble :(  (Read 3341 times)
Offline Sgt Apone
« on: 17 February 2008, 18:51 »
Its giving me headache and i just want some clues to what it is before i take it too the garage.  Normally when i first run it from cold i suffer from a great loose of power, stutters and if i drop the clutch and rev for 30secs it will either cure it or just make it run better till it clears. dosnt happen every time i start the car either which is weird.  The engine does seem too have leaked a tiny bit of oil but this morning i looked and nothing, its like its playing with me. it does burn oil but not major amounts and when it runs right it runs 100% right. only other thing to add to this is where the belts are on the engine, seems to sound different, you know drive you care forever and you just seem to notice when theres a noise you've not heard before.
Is all this linked or could it be separate problems?? cheers ppl   :smiley:
 EDIT: Erm on a side note, is there ECU in M reg GTi's and if so where the hell is it lol
« Last Edit: 17 February 2008, 19:00 by Sgt Apone »
Offline Mikester
  • Civic Type R
Re: MK3 golf GTI 2.0 8V with running trouble :(
« Reply #1 on: 17 February 2008, 19:09 »
Under the rain tray is where you find the ecu  :wink:
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 17 February 2008, 19:13 »
try a new temp sensor for your cold running issues..and take the plastic cover where your wipers are off and the ecu is behind the passenger side wiper
Offline Sgt Apone
« Reply #3 on: 17 February 2008, 19:56 »
Thanks on the ECU and the temp sensor thing, is that like arm or an arm and a leg??  :smiley:
  • Back in a Mk3...
« Reply #4 on: 17 February 2008, 20:06 »
temp sensors are about £12 for an intermotor one or £18 for bosch
Offline Sgt Apone
« Reply #5 on: 17 February 2008, 20:15 »
ok cheers, ill have a look around tomorrow see what i can see, fingers crossed thats all it is. thanks again.
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #6 on: 18 February 2008, 14:01 »
i have exactly the same trouble, hard starting from cold stuttery power and not instant power when i accelerate.
Someone did mention about the temp sensor but i thought this is to do with the fan for cooling..?
where is the temp sensor located is it the one that sits in the water housing on the right of the engine and has a 90deg angle pipe and sensor sits right here???
many thanks
dan
  • Back in a Mk3...
« Reply #7 on: 18 February 2008, 18:49 »
my guide...it's an 8v but the 16v has the temp sensor in a similar place
Offline golf-gti-matt
« Reply #8 on: 18 February 2008, 23:00 »
Thats one clean engine bay, fair play!  :smiley:
  • Back in a Mk3...
« Reply #9 on: 19 February 2008, 00:00 »
you should ask to see kells under bonnet cleanseness!!! mines looks like a scrapper compared to his!!
oh and mines never being cleaned,polished or anything else in the 2years I've had it! (I'm far too lazy)
