Author Topic: SMOKE PROBLEMS MK4 GTI TURBO 150 BHP DIESEL 03  (Read 1953 times)
Offline jason
« on: 17 February 2008, 18:01 »
Can anyone suggest how to deal with this. Recently very smokey from exhaust even when not flooring it. A blast down the motorway used to help clear things out but this is now all the time. Any sort of tap on the throttle and I get a puff of smoke which is shown up clearly in light from cars behind at nights and also visible day time.  Ive tried different garages for diesel to no avail. Clean car but dirty exhaust most annoying. Help and input would be greatly appreciated.
Offline samy_1800_turbo
Re: SMOKE PROBLEMS MK4 GTI TURBO 150 BHP DIESEL 03
« Reply #1 on: 17 February 2008, 18:16 »
first thing id check would be to see if your air filter is dirty or blocked up with crap coz if so it will make the car run rich and your get smoke out the exhaust.
Offline Ridg
  • TDI - Soot Happens!
« Reply #2 on: 17 February 2008, 18:25 »
after checking the air filter i'd check all the vacuum hoses as you could have a leak somewhere causing the mixture to run too neat eg not enough air getting in
Offline AndyX
« Reply #3 on: 17 February 2008, 20:13 »
I had a similar problem with a BX Gti and it turned out it was the valve stem seals. I have absolutely no idea what they are though! :huh:
Offline AlanD
  • MK5 2.0T 16v
« Reply #4 on: 18 February 2008, 09:40 »
It's called a desiel ! :D ;)
(im such a prick ! :D)
Offline Rhyso
« Reply #5 on: 18 February 2008, 09:51 »
especially as you can't even spell 'diesel'  :tongue: :rolleyes: :laugh:
Offline AlanD
  • MK5 2.0T 16v
« Reply #6 on: 18 February 2008, 10:01 »
B0llocks  :angry:
Offline jason
« Reply #7 on: 18 February 2008, 19:43 »
Thanks for all the useful input. So I dont get turned over by the garage can you tell me what a vacuum hose is. Ta!
Offline Ridg
« Reply #8 on: 18 February 2008, 20:09 »
basically its the hoses that run from the turbo to the intercooler and back from the intercooler
if one of these goes then air escapes from the turbo and it can't get enough air into the mix resulting in a nice white/blueish white smoke.
if you've got a jack then you can inspect them yourself
