Author Topic: oil on HT leads?  (Read 1540 times)
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
oil on HT leads?
« on: 17 February 2008, 17:51 »
Just changed my HT leads set as one of them had a rubbish connection...
On about 2 of the old ones, when I pulled them out, there was quite a bit of oil on the bottom of them (long end into the spark plugs).
Is this normal?
Dont think the spark plugs have been changed for a while, so that might be it?
Offline Pete Taylor
Re: oil on HT leads?
« Reply #1 on: 17 February 2008, 17:55 »
That'll be a rocker cover leaking oil into the spark plug ports which also causes misfires etc if too bad. Must be quite bad for you to notice it though. A new rocker cover gasket is about a fiver and dead easy to change. But you have the ABF so you have to take off all the inlet manifold to get to it first!
