Author Topic: How to - Resync your keys / Change key battery  (Read 89793 times)
Offline Rhyso
« on: 17 February 2008, 16:42 »
sometimes your remotes can lose their coding with the car meaning your remote won't lock / unlock but there is a solution  :smiley:
you need two remotes for this!!
1. Place your first key into the ignition and turn to the second notch (do not start the car)
2. Now close the door and place your second key into the handle lock
3. Turn the key to the lock position and let it spring back to the central position.
4. Hold down the Lock button on your new remote, you may hear a bleep from the car
5. Now unlock the car using the key in the barrel and remove, then take your first key out of the ignition
6. Close the door
7. Your remote should now be coded
Also to change the keys battery this link will help:
http://www.riskin.org/vwkey/
Try these if your silver key clip is broken on your fob, You can buy just the cover:
http://www.dealextreme.com/details.dx/sku.16404
Got VAGCOM and only one key?
http://www.ross-tech.com/vag-com/cars/vw-remote-matching.html
« Last Edit: 28 June 2010, 14:57 by Rhyso »
Offline MikeGTI...
Re: How to - Resync you keys
« Reply #1 on: 30 September 2008, 11:47 »
Hello, ive brought a used Key from Ebay with a new blade which im going to get cut, however I do not have any key holes in either doors on my Golf.  Brought the car used and im not sure if its had the mod done for the de-lock, or whether its been like that from new?  My car is a 2000 year X reg VW Golf GTI 1.8 Turbo, 3 door.  Ive heard that you have to use Vagcom connected to the ECU with a usb lead and a laptop in order to program a new keyfob?
Any ideas would be a great help as im not sure how im going to program my new key.
Offline DarkGti
Re: How to - Resync your keys / Change key battery
« Reply #2 on: 03 June 2010, 22:20 »
justed changed my battery and now the bloody key fob dont work :angry: :angry: have tried syncing it and still nothing
Offline DarkGti
« Reply #3 on: 07 June 2010, 17:24 »
DONT WORK :angry:
Offline wessexgti
« Reply #4 on: 13 September 2010, 18:30 »
who sells the batterys for the remote ? halfords etc or is it a vw dealership only thing?
cheers  :undecided:
Offline Rhyso
« Reply #5 on: 14 September 2010, 09:56 »
cheers  :undecided:
Halfords / Dealers or possibly somewhere like Timsons
Its basically a watch battery
Offline wessexgti
« Reply #6 on: 14 September 2010, 21:15 »
cheers  :undecided:
ok,thanks
Offline Ant1981
  • Feed me, prod me
« Reply #7 on: 17 May 2011, 13:19 »
Will this code the key to start the ingition?
'09 Kawasaki Ninja ZX-6R
Offline Rhyso
« Reply #8 on: 17 May 2011, 13:26 »
No - this only does the remote function.  The immobiliser side of things needs to be done via VAGCOM / dealer.
If you're only replacing the battery then the immobiliser won't need re-programming; if you've had a new key or the immobiliser chip inside the fob has become damaged then it will need VAGCOM / dealer visit
Offline Agreeable Slick
  • Unit
« Reply #9 on: 17 May 2011, 13:30 »
IIRC - Vagcom cannot do key SKB(??) code retrieval.
I've had a look on mine and it isn't apparent.
I think there is another bit of software (dos based) that is needed to acquire the code for the immobiliser. Alternatively, I have heard that VW keep a record of all codes applied to each vehicle which a UK dealer will get from them.
