Author Topic: driver carb  (Read 798 times)
Offline ro55
driver carb
« on: 17 February 2008, 11:25 »
hi there ive recently got into mk2 golfs and ive brought a 1.6 driver,theres a fault with the carb though,i understand this is common on them.i was  wondering if a carb from a j reg 1.6 will fit and be ok?or would a carb from a 1.8 driver work aswell?thanks in advance
« Last Edit: 17 February 2008, 11:36 by ro55 »
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: driver carb
« Reply #1 on: 17 February 2008, 11:43 »
Any 1600 carb should fit and run ok,  if you fit a 1.8L carb it may need a diffrent size jet, you might get away with just tweeking it but i would recomend using one off another 1600.  The carbs off bigger engines are made to have a larger amount of air draw past and reducing the air intake (using a smaller engine) will mess up the fueling.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
