Author Topic: engine mod  (Read 699 times)
Offline slowgti
engine mod
« on: 17 February 2008, 04:10 »
ive heard you all rambling on about swapping out the engine block for one off a 2.0l engine..
a 2.0l engine off what exactly? and does it all just bolt straight in?
Offline gavL
Re: engine mod
« Reply #1 on: 17 February 2008, 11:49 »
What car have you got then we can discuss this a little further?
Engine Type, Injection System or Carb, Engine Size and Year :)
| DubNorthEast |
Offline slowgti
Re: engine mod
« Reply #2 on: 18 February 2008, 03:52 »
wellllllll its 1800cc, k-jet injection, made in 1984. engine type.. no idea. the engine number is EVO28828 if thats worth anything.
Re: engine mod
« Reply #3 on: 18 February 2008, 12:13 »
ok so you gots an 8v GTI k-jet with engine code of EV.  what you need is a 2.0 8v lump from a MK3 Golf Passat or Audi, VW code of 2e works, as does audi code of 3a.  Only issue is since you're on k-jet you'll need the TSR dizzy adaptor ring, and you need to swap the dizzy gear from the MK3 dizzy to your old dizzy.
Later MK3 codes work too, but I can't remember the engine codes off had, as do Audi ones, as long as its a 4pot 8v lump it should work!
