Author Topic: Noisey fuel pump  (Read 1248 times)
Offline BIG D
Noisey fuel pump
« on: 16 February 2008, 22:26 »
I heard it today whining all the time and the car wasnt running very well is this normall or do i need a new pump.Ive heard that if the lift pump go's it can put extra strain on the main pump
any info will be very helpfull
Thanks Dave
Offline md1980
Re: Noisey fuel pump
« Reply #1 on: 16 February 2008, 22:35 »
it may be your in tank pump is shafted this will make the main pump work harder and could cause it to be noisey
Offline BIG D
« Reply #2 on: 16 February 2008, 23:25 »
Is there anyway of testing this
Offline Conker
« Reply #3 on: 17 February 2008, 12:56 »
You can unplug the electrical connector to your main fuel pump, turn on the ignition, and you should hear the lift pump prime apparently. They are dead cheap to replace by the way and easy to access via the access panel under the boot carpet.
Offline BIG D
« Reply #4 on: 17 February 2008, 13:21 »
I cant hear it primeing but if i unplug it would make a diffrence to the running because it doesnt
« Reply #5 on: 18 February 2008, 12:08 »
not at first no, eventually the main pump will get weaker and die.
Offline Simeon
« Reply #6 on: 25 February 2008, 18:33 »
How loud is the lift pump when it primes? I have a the same problem so have done as you suggested and can't hear it when sat in the car. Do you need to have your head in the boot to hear it or is mine knackered? cheers
« Reply #7 on: 25 February 2008, 18:54 »
its pretty quiet, best way to hear it is to disconnect the plug for the main pump and turn the key 1 click, you'll hear it then :)  You could put your eart up to the round metal flap in the boot too, but it can still be prety hard to hear i over the noise of the main pump.
Offline Simeon
« Reply #8 on: 25 February 2008, 19:12 »
Ah, yeah I did disconnect the main pump but still couldn't hear anything. Guess I need to replace the lift pump then
Offline Conker
« Reply #9 on: 25 February 2008, 21:06 »
Dont sweat the big stuff... Only £20 or so ye olde english pound sterling for a lift pump the last time I checked.
« Last Edit: 25 February 2008, 21:54 by Conker »
