Author Topic: Differances between Mk3 and Mk2 springs  (Read 2060 times)
Offline c8dhc
« on: 16 February 2008, 22:00 »
I bought some springs a while ago for my Mk2 Gti 16v and finally got around to fitting them today.
The lad I bought them off said he had them fitted to a Mk3, but were designed to fit a Mk2. Rear ones fit fine but the problem is the fronts don't fit correctly. The top of the spring has a smaller centre on the new ones so the upper spring plate does not fit inside the spring.
Im hoping that if I get hold of some upper spring plates from a Mk3 then that will sort it. Anyone got some/know if they would fit?
If not then its back on with the originals
Trackday Mk2 GTi 16v
Offline boneybradley
  • Back in a Mk3...
Re: Differances between Mk3 and Mk2 springs
« Reply #1 on: 16 February 2008, 22:08 »
the early mk3 till about 94 had identical springs all round to the mk2 (80mm pigtials on the front i believe) and changed in 94ish to 65mm pigtials and thats looks like what youve got!! the rear shocks and springs are the same whatever the year...
Offline c8dhc
« Reply #2 on: 16 February 2008, 22:16 »
Do you know if I can just fit the smaller upper spring plates from a later Mk3 then?
  • Back in a Mk3...
« Reply #3 on: 16 February 2008, 22:19 »
The top mounts are different for the later springs...but if you have a friendly local factor you could see if some spring plates fit.... I've fitted larger springs using new top plates but not the other way round!!
Offline saul79
« Reply #4 on: 17 February 2008, 00:02 »
the lowering springs i had for a 96 golf where the ones you need with the wider top coil ,i had smaller cups and welded brackets to em so they would fit lol ,but you cant as there smaller
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline c8dhc
« Reply #5 on: 19 February 2008, 17:28 »
Don't suppose you have the old smaller type knocking about?
Tried the wanted section but no replies.
Do GSF do them as they have just opened a new unit nearby so I could pop in at w.end?
Offline saul79
« Reply #6 on: 19 February 2008, 17:55 »
yep i got 2 off the buggers ,seen them today in me dads garage.if you need em then let me know :smiley:
Offline c8dhc
« Reply #7 on: 20 February 2008, 19:51 »
pm sent
Offline saul79
« Reply #8 on: 20 February 2008, 22:39 »
pm replyed  :smiley:
