Author Topic: Differances between Mk2 + Mk3 suspension?  (Read 675 times)
Offline c8dhc
« on: 16 February 2008, 21:58 »
I bought some springs a while ago for my Mk2 Gti 16v and finally got around to fitting them today.
The lad I bought them off said he had them fitted to a Mk3, but were designed to fit a Mk2. Rear ones fit fine but the problem is the fronts don't fit correctly. The top of the spring has a smaller centre on the new ones so the upper spring plate does not fit inside the spring.
Im hoping that if I get hold of some upper spring plates from a Mk3 then that will sort it. Anyone got some/know if they would fit?
If not then its back on with the originals
Trackday Mk2 GTi 16v
Offline boneybradley
  • Back in a Mk3...
Re: Differances between Mk2 + Mk3 suspension?
« Reply #1 on: 16 February 2008, 22:15 »
replied in the mk3 thread...
but for everyone else... front springs for mk2 & mk3 to 94 is 80mm pigtail..and mk3 94 on is 65mm..rears are all the same whatever the year
