Author Topic: lowering problems golf vr6  (Read 1610 times)
Offline DRUE1
« on: 16 February 2008, 17:18 »
right i cant get the nut off the top mounts.there so solid that the allenkey broke in one top mount so im well stumped.ive tryed mole grips on the leg but still turns.any ideas or help please before i get the grinder out and and cut the hole leg off :cry: :cry:
Offline saul79
Re: lowering problems golf vr6
« Reply #1 on: 16 February 2008, 17:36 »
you not got a compressor and airgun them? :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline DRUE1
« Reply #2 on: 16 February 2008, 18:13 »
not got one of them looks like i will have to take it too a garage and get them to take them off
Offline saul79
« Reply #3 on: 16 February 2008, 19:23 »
did you have the spring clamps on ?
Offline DRUE1
« Reply #4 on: 16 February 2008, 20:11 »
not got a spring clamp
Offline saul79
« Reply #5 on: 16 February 2008, 23:58 »
you need spring clamps to compress spring ,if you had undone the nut on the top you wouldn't off had a face mate.
compress spring and the nut will be easier to undo :smiley:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #6 on: 17 February 2008, 01:01 »
drive it to a garage and ask nicely for them to zap it off and then back on loosly,  if its not to far, keep the bolts loose!  if your local garage is a few miles away bang them back up with the air gun, either way it will be easyer when you come to undo it
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline saul79
« Reply #7 on: 17 February 2008, 11:38 »
hes not got any spring compressors so it cant take it off  :wink:
