Author Topic: g60 brakes for mk1  (Read 4000 times)
Re: g60 brakes for mk1
« Reply #10 on: 19 February 2008, 13:37 »
If so then you got Scirocco 16v/early audi 80 256 front calipers & carriers, quite rare :)
well technically tyhe calipers are the same as MK2 ones, just with a smaller bleed nipple.  It's the carriers that are the rare/expensive bit!
Offline bad-vw-boy
  • Man on a golf mission
« Reply #11 on: 19 February 2008, 13:39 »
Well you learn something new everyday... :smiley:
« Reply #12 on: 19 February 2008, 13:46 »
there is another optiuon for bigger brakes on a MK1, some vauxhaul 256/280 brakes fit a MK1.  What you do is get either shouldered bolts or make up a spacer slieve as the mounting hole is bigger and deeper, use vaux pads & flexis and MK2 256 or 280 brake discs :)
