Author Topic: Central locking.......i'm trapped!  (Read 1453 times)
Offline filthy
« on: 15 February 2008, 21:50 »
Hey guys, had my immobiliser disconnected the other day as a foreigner by a friend of a friend (i know...), now the central locking is all screwed up....
When i unlock the car, only the drivers door unlocks ( no, not even the fuel flap... :angry:) and then it locks itself again straight away...to get out I have to wind down the window and unlock the door with the key from the outside
The lad can't get over till next week, but I need to use the car, is there any way of disconnecting the central locking, I cant see a fuse for it..... :sad:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Central locking.......i'm trapped!
« Reply #1 on: 15 February 2008, 22:01 »
If you can get into the boot you could unplug all the power cables to the central locking pump,  then u can use the key to manualy lock and unlock it.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline filthy
« Reply #2 on: 15 February 2008, 22:41 »
Ah genius! I can get in through the rear seats, I had to earlier to pull back the pin for the fuel flap, just so I could put juice in it.... :rolleyes:
Offline raylee25
« Reply #3 on: 15 February 2008, 22:50 »
If you're trapped. how did you type this post?
Offline Mikester
  • Civic Type R
« Reply #4 on: 15 February 2008, 23:25 »
Wireless internet. The fuse for central locking, what else does it control?
Offline filthy
« Reply #5 on: 15 February 2008, 23:37 »
Damn, I've been rumbled! Ok, I WAS trapped!  :grin:
