Author Topic: This cant be normal can it?  (Read 1823 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 15 February 2008, 19:14 »
I took my engine breather pipe off today and once again it will packed FULL of Yellow gunge!!!  and i mean PACKED!  I dont see how so much moisture gets into my engine,  i NEVER loose coolent and im sure the head gasket is fine,   Why does it collect here?  It lines the intake pipes back into the throttle body!
Shall i just keep cleaning it out?  I think thats why i loose economy somtimes,  Mine is a 1.4L engine and they like to breath to run efficently.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Grim_Reaper
  • warningz...i haz powaz
Re: This cant be normal can it?
« Reply #1 on: 15 February 2008, 19:19 »
do you do alot of short journeys??? you can get "mayo" from doing many short journeys on some cars
Offline saul79
« Reply #2 on: 15 February 2008, 21:00 »
agree.
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Rmachines
« Reply #3 on: 15 February 2008, 21:16 »
I know its common, and i do, but for every short journy, i do one long one after it.  so would expect it to burn off?
Offline filthy
« Reply #4 on: 15 February 2008, 21:44 »
mayo doesn't really burn off, its just gunge, just blow it out every now and then, you'll be fine  :smiley:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline Rmachines
« Reply #5 on: 15 February 2008, 21:59 »
Ah goody!  could that be the cause of my intermitant ecconomy and power loss problem?  Seems to come and go!   the pipe was also kinked which wouldnt help lol
Offline filthy
« Reply #6 on: 15 February 2008, 22:03 »
Might be, but clean out your throttle body as well, mine lost power on the M42 today, also, wouldn't idle above 600 rpm, cleaned the throttle body, and she runs like a new 'un again....kind of!
Offline mark j b
« Reply #7 on: 15 February 2008, 22:19 »
how do you clean the throttle body?
Offline Rmachines
« Reply #8 on: 16 February 2008, 01:21 »
I have cleaned the TB a few times,  Just wiped it out and used some brake and clutch cleaning fluid.  Made no diffrence what so ever  :grin:
Offline Grim_Reaper
« Reply #9 on: 16 February 2008, 19:05 »
do a search mate...it been made a sticky i think
