Author Topic: ABF mk3 16v starting problem  (Read 7400 times)
Offline san
« on: 15 February 2008, 16:03 »
I have a 97 gti mk3 16v abf, and the car wont start. It fires up but straight away cuts out and then wont start at all. Ive checked spark, fuel pump primes, I just cant figure out what it could be. Would appreciate any help.
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: ABF mk3 16v starting problem
« Reply #1 on: 15 February 2008, 20:49 »
Crankshaft position sensor.
Offline ben44
« Reply #2 on: 16 February 2008, 20:36 »
possible factory imobilizer problem? with the vw immobilizer it will let the car run for three seconds then cut out. try using your spare key!
if not then, crank position sensor or ecu relay............
 :smiley:
My signiture sucks..........................
« Reply #3 on: 18 February 2008, 11:56 »
yeah sounds exactly like an immobilisor fault, get yourself a vag-com cable and a laptop, no point fubling around in the dark when you can just click a buttoin and have it tell you whats up ;)
Offline ben44
« Reply #4 on: 18 February 2008, 21:18 »
if only working women out was this easy!
Offline somerset_vdub
« Reply #5 on: 19 February 2008, 17:34 »
 check ur throttle body
  i needed a sensor on mine to ensure it never cutout again.
   it seems to be a big problem and a b!tch to get right
volkswagens dont grow old ...............................  they just get faster !!!!!!!!!!!!
Offline san
« Reply #6 on: 19 February 2008, 21:54 »
After cranking the engine for 2 or 3 minutes it eventually started but sounded lumpy and had a misfire. I pressed the accelerator and it just died. It started again eventually and I left it running for a while to warm up and it sounded a lot smoother. Took it for a spin and it seemed to run fine but on gear change the revs stay up for a second.  Also when revving the car on idle the revs seem to go back down slowly. The same starting problem happens when the engine is cold. Ive changed the ecu temp sensor, crank sensor, spark plugs, then I had it plugged into VAGCOM but no faults came up.  :angry:
Offline DazVR6
« Reply #7 on: 20 February 2008, 00:29 »
So have you changed the ecu and fuel pump relays..? if not then they are numbered 30 and 167 and cost about £20 for both from the stealers.
Offline Pete Taylor
« Reply #8 on: 20 February 2008, 09:19 »
Check the vac hose that runs from the top corner of the inlet manifold, through the bulkhead to the ECU
Offline sk8boy73
« Reply #9 on: 24 February 2008, 23:24 »
had this prob myself.
mine was the brown thiing around the ignition barrel(not sure what its called)
it picks up the signal from the chip in the key.
what i had to do was trace the wire from it to the box just under the dash near the steering column.
you need to move this wire away from all the other wires>
apparently it picks up interfearance from the other wires!
sounds wired but it worked on mine and it has never not started since
