Author Topic: 16v hubs 280mm disc's  (Read 810 times)
Offline BIG D
« on: 14 February 2008, 20:12 »
Do they fit or are the g60 carriers bigger if so can you buy brackets
Thanks dave
Offline Diamond Hell
  • Opinions я Us
Re: 16v hubs 280mm disc's
« Reply #1 on: 14 February 2008, 22:07 »
You need the bigger caliper carriers, is all.
Probably VAG or scrapper only.
Part No. 857 615 125
Offline dabill
« Reply #2 on: 15 February 2008, 10:44 »
off to the scrappers, audi 280mm carriers work, along with vr6 mk3 golfs, passats, seats, just take a tape, measure the size of disc, and if its 280mm and Vag, it will fit. got mine off a audi 80 sport auto. 30£ for the lot, hubs, carriers and calipers. ended up changing the hubs for some 16v ones though cos the audi ones were gash!
noble tuned - and still not fast enough!
Offline leavingeasy
« Reply #3 on: 15 February 2008, 12:37 »
Keep an eye on ebay too if you dont want to get your hands dirty- often pop up on there.
coming to some armco near you soon.....
Offline BIG D
« Reply #4 on: 15 February 2008, 17:44 »
Thanks for the info
« Reply #5 on: 18 February 2008, 12:31 »
be aware though that 280 calipers are wider to make up for the thicker brake disc, you can use the 256 caliper with part worn pads or by grinding the slider pins down a wee bit.
