Author Topic: car wont start  (Read 1398 times)
Offline TRANTER
  • golf mkII gti 8v
car wont start
« on: 14 February 2008, 17:39 »
can any one help my car wont start it turns over but wont kick in , ive had a look at everything i can think of but not sure what it is
Offline TRANTER
  • golf mkII gti 8v
Re: car wont start
« Reply #1 on: 14 February 2008, 17:43 »
Tryed
1 : battery but why would it turn over even with a booster pack
2 : fuel got 1/4 of a tank
3 : fuel pump primes after trying to start but not before
4 : all fuses fine
5 : all levels fine
6 : all plugs and leads
7 : ? help
anyone got anything else to add its in primer till sat ready for respray so cnt do much ill then but i will keep in mind all that is told or anyone near telford who could help cheers tranter
its an 86 k-jet 1.8 8v
Offline Conker
Re: car wont start
« Reply #2 on: 14 February 2008, 17:55 »
Pull a sparkplug and see if its sparking on turnover (if you've got the tools to hand?)
A while back mine wouldn't start after doing some engine work. A jump start wouldn't get it going, but a bump start worked first time, and its been fine since - must be something to do with fuel pressures etc.
Offline TRANTER
  • golf mkII gti 8v
Re: car wont start
« Reply #3 on: 14 February 2008, 17:57 »
havent seen if it has a spark but i have tryed bump start and off another car neither works. its was driving then when it was idling it would cut off then it would start then cut off while idling then eventualy wouldnt start any idea
Offline Conker
Re: car wont start
« Reply #4 on: 14 February 2008, 17:58 »
8v or 16v ??
Offline TRANTER
  • golf mkII gti 8v
Re: car wont start
« Reply #5 on: 14 February 2008, 18:00 »
8v mate i just dont get it could it be the lift pump or main fuel pump metering head i just dnt no
Offline d-evilgenius
Re: car wont start
« Reply #6 on: 14 February 2008, 23:26 »
TRANTER geza i feel your pain the same things happening to my 8v the car was running mint then suddenly started cutting out now it wont turn over its pickling my brain still havent found out what it is i keep tellin myself its gotta be something stupid. ive checked the battery which is on 1147v changed the spark plugs cleaned most the connectors i could see HELP!!
thnks
 :cry:
Offline takethefifth
Re: car wont start
« Reply #7 on: 15 February 2008, 01:16 »
I'd check the spark first and if thats ok on all cylinders then lift pump and main pump.
If theres a weak or no spark change the plugs first, then HT leads and then dizzy cap and rotor. If there's still no spark after that then change the coil.
Offline mongchops
Re: car wont start
« Reply #8 on: 15 February 2008, 09:30 »
Just had a similar problem. The AA man traced it to a faulty hall chip in the dizzy. Changed the dizzy, alls OK with the world. :grin:
Re: car wont start
« Reply #9 on: 15 February 2008, 09:34 »
sound lads ill give that a try fingers crossed
