Author Topic: Painting calipers dragon green  (Read 4580 times)
Offline saul79
Re: Painting calipers dragon green
« Reply #10 on: 14 February 2008, 22:50 »
dont use wd40 as its got silcone it and it will react with the paint -brake cleaner is the the best
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Mikester
  • Civic Type R
« Reply #11 on: 14 February 2008, 23:01 »
i just used a wire brush and then a damp cloth to get the dust off. Dont wnt to start lubbing your brakes!
AS for mixing the hamerite, once sum dust gets on them, they wont be perfect, so i wouldnt worry.
Offline al_bey
« Reply #12 on: 15 February 2008, 14:19 »
so saul, did you just use standard paint or heat resistant? I wont be using the WD40 then, i try and use that sh!t for everything!
kells
« Reply #13 on: 15 February 2008, 17:50 »
just use hammerite mate, they do a green metalic which is very similar to dragon green
Offline al_bey
« Reply #14 on: 15 February 2008, 18:35 »
oh ok, cheers mate
Offline Mikester
  • Civic Type R
« Reply #15 on: 15 February 2008, 23:28 »
Wire brush, damp clothe, few coats of hamerite, dont even need to take them off, just mask the discs a bit and use a SMALL brush. lol
Offline saul79
« Reply #16 on: 16 February 2008, 17:43 »
yes i did mate ,i also primed them white 1st
Offline Mikester
  • Civic Type R
« Reply #17 on: 16 February 2008, 18:19 »
I never primed mine...... Might do mine again soon :/
