Author Topic: heater matrix pressure valve leak  (Read 1199 times)
Offline richard s
« on: 13 February 2008, 21:04 »
i have a leak on one of the pressure valves that stops the heater matrix from bursting
none of the pipes fitted to the valve seem to leak but the valve is wet underneath
so would i be better off getting a new set of valves or binning the valves and fitting a mk3 matrix
Offline takethefifth
Re: heater matrix pressure valve leak
« Reply #1 on: 14 February 2008, 11:41 »
The bypass valve?  Bin it and replace with copper tubing.
Offline midz16v
« Reply #2 on: 14 February 2008, 13:56 »
yeh binit,mines has never had the bypass valve fitted and still no problems :smiley:
Offline Horney
« Reply #3 on: 14 February 2008, 13:59 »
My old never had one fitted and it sprayed boiling hot water all over my feet. I was lucky I was wearing leather work shoes and not canvas trainers otherwise I'd have had badly burnt feet!
Nick
Offline richard s
« Reply #4 on: 14 February 2008, 21:19 »
looks like i will bin it but not till i get a mk3 matrix as i quite like having skin on my feet
as for matrix is it better to get one from dealers or ecp etc
« Reply #5 on: 15 February 2008, 01:03 »
Nick
 :laugh: Blimey! And i thought that was just the stuff of myths and legends! Glad you didn't get burnt!
« Reply #6 on: 18 February 2008, 12:25 »
go for one from gsf or ecp, will be fine.  just make sure its one specifically for a MK3 and then you mknow it wont need the bypass valves :)
Offline richard s
« Reply #7 on: 19 February 2008, 21:22 »
cheers john
