Author Topic: Engine Re-Mapping  (Read 6586 times)
Offline Rhyso
Re: Engine Re-Mapping
« Reply #20 on: 23 February 2008, 17:53 »
and the GT TDI 130??
CS
pretty much the same as long as you maintain the service intervals and use the correct spec of oil; very crucial as the 150 and 130 can and have been prone to premature cam wear.
ideally you do time and distance oil changes and use longlife oil - apparently its better for remapped cars
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
« Reply #21 on: 25 February 2008, 16:41 »
Custom code for me too.
i read it gave the best throughout the rev range. Though as mine is a N/A it appears to give the most benefit on bottom end torque.
Would you say it was worth it for the mk4 2.0ltr 8v?
Im considering doing it but will it void my warrantyas i have only just got the car from main dealer?
apologies for not replying sooner.
imo it was worth it. Low end torque is greatly improved (nothing compared to turbo models though, but thats a different ball game)
If your after driveability as a pose to outright BHP then go for it.
It also cured my cold starting problem.   :cool:
Offline Jamm89
  • Mk4 GTI 2ltr 3door Black
« Reply #22 on: 25 February 2008, 17:37 »
Where did you get yours done.
I rang a bloke up from custom code and he said that i would need to go to chesterfield to have it chipped.
Offline GTi-Matt
« Reply #23 on: 25 February 2008, 19:01 »
with the right exhaust and induction kit custom code say u can get 140 bhp outta the 2.0L: this is from there site.
Home  VW  Golf / Bora  2.0L 8V 115 BHP
2.0L 8V 115 BHP
IMPROVED THROTTLE RESPONSE AND DRIVABILITY.
CUSTOM-CODE IS THE OBVIOUS CHOICE FOR NORMALLY ASPIRATED PERFORMANCE SOFTWARE, ELIMINATING FLATSPOT'S GIVING AN IMPROVED THROTTLE RESPONSE AND DRIVABILITY
Custom Code Options:
Power
 Stock
 Phase One
 Phase Two
BHP
 115
 125-130
 130-140
Torque  ft/lb
 125
 130-135
 135-145
 or go to it if u dont undersatnd the way thats been copied!!!!
http://www.custom-code.co.uk/index.php?option=com_content&task=view&id=376&Itemid=80
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
« Reply #24 on: 25 February 2008, 19:10 »
All of the above is correct.
Ring them again and ask about the mobile unit. they came to my place of work to do mine.
As for the phase 2 - have you seen the price  :shocked:
Offline GTi-Matt
« Reply #25 on: 25 February 2008, 19:25 »
be worth every penny if u were keeping the car im 70-30 towards it
Offline richw911
« Reply #26 on: 25 February 2008, 19:48 »
Yeah sounds good that mate  :wink: But dont forget your insurance will go up with a remap put that to the cost of the remap- thats a fair bit of money.
Like you say tho mat if you a keeping the car then why not  :evil:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #27 on: 25 February 2008, 20:19 »
Yes, that custom code does seem expensive.
It's weird that chipped-uk do all the GTi's (& TDi's), bar the 2.0 8v?!   :huh:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #28 on: 25 February 2008, 21:01 »
Hi!
Have you called Jayson at chippeduk? I know he is a expert with the Bosch management systems.  I think he can also do the Siemens ECU in the 2.0 8v.  He uses the same Optican tool as we do which excludes the 2.0 8v ecus.  The ecu can be emulated direct to PCB, then once the remap file is produced it can be written direct to the eeprom.  I know other companies have tools which will do the 2.0 8v via OBD.
  I spent hours on my sister inlaws GTI Cab 2.0 8v and could not push any more than 10bhp 12NM max.  The power alone was not really noticable but applied with the rest of the setting in the remap the car feltl much sharper  and smoother.
 We dont do the 2.0 8v remaps as it take too long to do for so little power gains. Custom Code will have a stock of generic remap files which will suite all of the hardware and software version out there for the 2.0 8v.  If Custom Code have spent a lot of time on R&D whith there files then the price will reflect this.
Nick
EDIT:
In Fact just to ad to this.  There is an option for a mk4 2.0. 8v with a Bosch ME7 ecu which is much the same as the ME7.5 in the 1.8t, but I have only ever come across siemen ecus
« Last Edit: 25 February 2008, 21:41 by RTechUK »
 01455 617233
Offline Jamm89
« Reply #29 on: 25 February 2008, 21:43 »
The bloke said that they are doing a promotion and will remap it the 2.0ltr for 287 quid.
Sounds pretty resonable to me.
He said that i will see a 10% increase in torque and bhp.
Think that was stage one though
